re: Turn signals. Thanks everyone for the input. Logically it did not seem reasonable that every turn signal light plus the internal blinkers would not work unless the system wasn't getting a signal to begin with. That certainly pointed to the switch as the emergency flashers worked fine. Indeed it was the m-f switch. I fiddled around with it a bit to check the dentents and functions and all of a sudden I had turn signals again. Just a heads up.
On an observational front re the PT. I sure love this car!! Wanted one for years and I couldn't be happier. Supposedly the non turbo automatic is terribly slow -seems ok for my needs. The RPM at cruise is similar to my Mercury Mystique 2.5 liter which gets 24-28mpg driving about 70% at freeway speeds so I expect mileage to be better than it's reputation too. I plan to be Cruising for quite a while. Again, thanks.
Donn Granros
donn granros
