Thread: Fog lights
Old 18 Mar 2005, 02:04 pm
purple04 purple04 is offline
BEFORE you start write down your radio presets and if you have an auto trans, get a copy of the relearn procedure. You need to disconnect the battery. Make sure you have the tools needed, including the Torx bit for the multifunction switch. The little terminals snap into the connectors. Take the time to figure out which way the terminals face BEFORE putting them in. When you put the dash back together, have clean soft towels to wipe things down. Of course, most of this is only if you have to run the wiring.
Raising the car is a big help for installing the lights.
