quote:Originally posted by BumperBob
Got 'nuther question about changing the plugs, got out my Chilton's, and they add steps like relieving fuel pressure, disconnecting IAC motor, TPS sensor, the MAP sensor. Accel. cable, cruise cable, etc. Is this necessary? Or just overkill? [:I]
It is a 2003, so I take it the EGR tube step is eliminated too?
You can do it that way, if you want, mine's a "shortcut" method I picked up on Forums - you just prop thinks out of the way - quicker, easier & less chance to screw up!
