Old 27 Mar 2005, 07:12 pm
PTurbed PTurbed is offline
quote:Originally posted by quicksilverdon
Hmmm - Looks like the "stuff" is right back where it was - guess you take it off, put strut bar on & bolt "stuff" back...
QSD, the 3 thingies you talk about on the passenger side are your solenoids for the Crewz Control (with my Apologies to Crewzin [?]) [)] The BTG bar which is shown in the picture comes with a small bracket. It replaces the stock bracket and bolts to the backside of the bar. This one looks like an Auto, but on a 5 speed, there is also the clutch resorvoir over near the drivers side. Mine looked a little too tight to leave where it was so I simply repositioned it to a slightly different bracket. think I had to reroute the w/s washer hose to clear. [8)]
As far as the grille goes, it sounds very similar...2 small bolts on each side & lift straight up, 2 tabs near the bottom position it. [xx(] First time it sticks a little. Paint must not have been totally dry when they assembled it. [^]
PTurbed
