Old 29 Mar 2005, 08:28 am
I haven't taken panel off, but as to wiring - one of the plugs is on all the time, the other comes on with ignition, right? Pick the ignition-switched one and pull off the wires on the back. They sell clamp-on connectors that have metal teeth that puncture insulation & make contact. Another choice is to cut wires, strip a bit, and use wire nuts. The outlet is already fused, so you should be "good to go".
