jmack,
Your dealer's (or any Chrysler, Dodge, or Jeep) parts counterperson should be able to locate the shim part numbers. Your VIN number will lead them to the proper part number for the shims.
Remember, you should not use the anti-squeak spray on the inboard pad (the pad that touches the caliper piston).
QSD,
Yes, the GT and N/A use the same pads. Only the shims are different.
Scott
\"If you choose not to decide, you still have made a choice.\"
