Old 06 Apr 2005, 07:38 pm
Ctown Ctown is offline
ok THE PROBLEM OF THE AC IS RESOLVED
it's like what you guys said. The system is low on freon. I bought a kit with 134a freon on ebay for like $30 it came with a pressure gauge + hose. It's a simple process if you have a hayne manual. just plug it in and turn the car on with AC full blast. hayne warn to only use one can of 12 ounce but I have to refill it with up to 28 ounce(2 cans).
Like what u guys said. if the system is under 20psi the compressor would turn of but it'll turn back right on cause I have the AC ON but it's turn off right away.....on and off constantly. only 20+psi will keep the AC compressor on constantly.
Anyway one more problem solved out of alot of problem. The PT is not a quality built car I have to say compare to others in the same price range
