Old 09 Apr 2005, 02:07 pm
hyracer hyracer is offline
Normally the whole braking system is different for a disc/drum compared to a disc/disc. The master cylinder may have different valving or the system may have a proportioning valve to direct the correct fluid pressure between front and rear. You can't just slap on a set of rear discs and have the system balanced properly.
Deen
