Old 12 Apr 2005, 03:52 pm
Alini Alini is offline
I'm running an 05 GT 4 door, I have 10 PSI in first gear and 13 PSI in all others. Everything I have read says thats the right stock numbers. I have heard though that you cant play with boost unless you have Stage 1 installed otherwise the computer will keep adjusting to stock numbers.
Did you adjust the WGA at all?? if you just bolted in a replacement WGA without any adjustment to spring tension inside then you didnt improve anything.
Chris and Alison Nolan
