I wont be able to help too much but this is what happened with mine. I fitted aftermarket lights and was hoping that I could just use the wiring that everyone said was there this is what I found.
When I pulled the covers off I could see there was wiring and a plug cliped to were the covers fitted. The problem was the wires went into the firewall but not to the fuse box I couldn't get power to them from my switch. Were the fuse would go there was no clip thing for it to go into.
I ended up just making my own wiring up with a relay, switch and a little bit of wire and all is fine.
Good luck.
