Old 05 May 2005, 10:08 pm
Hooligan Hooligan is offline
quote:Originally posted by VellianPT
how hard is it to install under car neon? i got a set back in march but i'll finally be home from college to install it. Its Optix brand. I do also have acess to lift so that should make it eaiser, help and tips would be apreciated. i.e. where is it best to run the wires, i'll be using a remote switch for it so getting wires into the cabin isn't a problem
I and a friend installed a kit using jack stands and a floor jack. We ran the wires thru the plate that covers the clutch rod, it is located on the drivers side fire wall, it is oblong and is held to the firewall with 2 bolts. We had to run the wires for the control which changes colors and patterns.
