Old 06 May 2005, 10:01 pm
Sci-Fi Sci-Fi is offline
Yes...for the Koni's, you have to reuse the front struts and cut out part of the top and remove all the guts out of the strut. Then you have to drill a hole at the bottom so you can secure the Koni strut cartridge with a bolt. May need a washer if the hole isn't dead on and you have to slightly make the hole larger. I've asked Koni if they can make a proper strut for the PT, but they say nothing is planned in the future and doing the cutting and installing the cartridge is your only option. If you own a "Sawall" or know somebody that has one, borrow that (wear old clothes) and the cutting will be a lot easier and faster. Then file and round the edges as smooth as possible. If you own a die grinder, it will be a lot faster.
