quote:Originally posted by ocb1031
quote:Originally posted by PK Cruiser
I just installed mine last week & with work, school, & the gym, I haven't had time to breath...let alone go to the track...
Question. What are the intake silincer's?
There are 3 of them. One is the white doughnut in the top of the airbox. The second is the one at the bottom of the airbox going over to the fenderwell hole. The 3rd is in the turbo up to the airbox hose. The doughnut is easy to remove. The one at the bottom of the airbox you can make a mark that is flush with the inside of the airbox. There are 2 tabs on the outside of the airbox on the snorkle that you pry up to remove the whole silencer. Once removed you can cut off the part of the silencer inside the airbox with a hacksaw. Then pop the snorkle back into the airbox. Now that silencer is gone and you still have the snorkle drawing cold air in from the fenderwell hole. The turbo up hose to the airbox needs to be replaced. You can make one or if you want to spend the money you can buy one.
