Old 10 May 2005, 12:02 am
GR8FLPT GR8FLPT is offline
Hmmm. start with:
stage 1 kit
then add rear sway bar & end links kit
VAk pipe kit
02 pipe
3" downpipe
Mopar/Borla dual exhaust or single if you don't want the second cutout
adding a PSi-Fi powerpaq would probably void the warranty unless you can hide it or remove it before service.
If you really have 5K to spend, think about boring out the TB, Porting the intake manifold, having the heads reworked
then add a bigger turbo.
You can probably get all this & still have some $$$ left over. I probably forgot some stuff but I'm sure some one else will chime in... [8)]
04 GT 5 spd, S1, Mopar Sways, Eibach springs, Airbox mod, K&N drop-in filter, AGP & AMX hard pipes, debadged, PTeazer grill, bumperette, rollpan, Cowl Induction hood & other assorted painted parts!!!
