You can't use it in place of Stage 1 because you'll get an overboost code and a check engine light, plus your ecu will pull and retard the timing and you'll lose horsepower. We use it to raise boost after stage 1 for and added kick in the pants. [8)]
<div align=\"right\"><h2><b><i>Can we say Sleeper?</i></b></h2></div id=\"right\"><div align=\"right\">  </div id=\"right\">
