quote:Originally posted by rszappa1
I am so glad you posted. I really like the grill and do not want to send it back. It looks as if the outer vertical bars are what hit the two bolts. and as you stated they are there to join the front fascia to the fender. So it sound as if the earlier models did not have them. When you removed the bolts did you have any problems with any play in that area from removing the bolts....Again thanks for your post....
No problems, no movement, but I saved the bolts just in case....
