QSD is correct.
The recal is only for the PS hose rubbing against the auto trans case and causing a leak.
You simply have a leaking PS hose.
Either it's rubbed against something else (you don't have an auto tranny case to rub against), the crimped ends are leaking, or the leak is running down the hose from above.
