Old 23 May 2005, 08:45 am
hyracer hyracer is offline
Change your oil as recommended and allow at least 1-3 minutes of cool down time (depending on how hard your've just run it) with the engine idling before you shut the car off. You can install a Turbo Timer to do the last part for you.
Deen
