Old 26 May 2005, 07:54 am
hyracer hyracer is offline
Rapid ticking could be valve adjustment. A grating sound could be your turbo cartridge is failing and the blades are striking the shell...if that is the case it would be a perfect time to upgrade to a larger turbo.
Actually it would be very hard to diagnois your problem without hearing the sound.
Deen
