If you do not wire up the secondary cable your engine light will come up, what you have to do is remove the factory connector on the block and replace it with a T connector..make sure you have the right threading on it and. This way you're happy because your oil pressure gauge works and your ECM does not freak out.
-SS Cruiser
Baddest Cruiser around ( Second to Bob's ofcourse )
