Thread: tire change
Old 30 May 2005, 05:50 pm
corvairbob corvairbob is offline
thanks the tire are low profile fyi. with only 2" from the road to the rims i will fit it into a low profile tire. thanks for the info on the 15" tires maybe someone has found a combo that works. i know about the speedo and if i find the correct combo then i will address the speedo. i have used tires with this amount of tire to road clearence and after i changed to a larger tire to road profile the ride improved 1000% . the tires do absorb huge amounts of road shock.
