3BarBoost said the PCM/ECU was calibrated to run best with the factory airbox and if you were going to mod spend your money on the exhaust side. I run AMX's turbo to factory air box pipe, a drop in K&N filter and am still the quickest factory turbo GT (non-nitrous)out there.
The carb Mfg.'s say don't over carb (go to big), the cam Mfg.'s say don't over cam for the engine (bigger is NOT always better), 3BarBoost
said concentrate on the exhaust side...
Yet it amazes me the amount of people that disregard the experts advice and still make the same mistakes as the kids I knew growing up 40 years ago. But that's O.K. as I take great pleasure on beating them on the street or at the track.
Deen[8)]
