Iggman stated the most probable cause for your flashing brake light during acceleration but keep something else in mind. When you check your brake fluid, if it's low, where did it go? Barring leaks, your brake pads and/or shoes, if you have rear drum brakes, are probably getting low. There have been quite a few entries on the forums where people have complained that their pads have worn down to the point of ruining the rotors with no previous sounds or warnings.....until the metal to metal grinding. Since you're noticing the flashing brake light, it's probably past time to check your brakes, and be sure to check all of them. At times, the actuator in only one of the wheels may stick and cause premature wear from the pads dragging on the rotor. If the pads are 1/8 inch thick or less, replace them.
Hope my $.02 helps.
Mel in Gilroy
Garlic Capitol of the World
Cranberry 28G, Loaded
