Hope these help:
Ball Joint Stud Pinch Bolt 70 ft lbs
Hub Nut 180 ft lbs
Disc Brake Caliper Adapter Knuckle Bolts 77 ft lbs
Lower Control Arm Front Pivot Bolt 125 ft lbs
Lower Control Arm Rear Pivot Bolt 185 ft lbs
Stabilizer Bar Cushion Retainer Bolts 21 ft lbs (250 in lbs)
Stabilizer Bar Link Nuts 21 ft lbs (250 in lbs)
Strut Clevis-to-Knuckle Nuts 40 ft lbs + 90° turn
Strut Shaft Nut 55 ft lbs
Strut-to-Tower Nuts 25 ft lbs
Tie Rod Adjuster Jam Nut 55 ft lbs
Tie Rod End-to-Knuckle Nut 40 ft lbs
Wheel Bearing Retainer Plate Bolts 21 ft lbs (250 in lbs)
Wheel Mounting (Lug) Nuts 100ft lbs
