Old 15 Jun 2005, 06:17 am
hyracer hyracer is offline
The SRT4 folks have experianced coil failures with aftermarket coils. The general consensus is to keep the stock coil.
If you want to ignore that fact, then you should carry your stock coil and tools with you so you won't be stranded when it does finally fail.
Deen
