quote:Originally posted by gooberff
I began installing stage 1 today and have a problem. After removing the PCM and the mounting bracket from the pcm, i attempted to install the bracket on the new pcm. the screws would not start and on closer inspection i discovered the new pcm was not tapped to receive the screws. Has anyone else had this problem? i will call T Thrift tommorrow at haynes to see if they can help me with this problem. For now i am dead in the water.
Can i install the injectors and run them with the stock pcm without any damage?
I've heard this before. Can you tap them yourself?
You must have an '03 and yes you can install the injectors. Those are the same injectors that are in the '04-'05.
