Thread: Hose head
Old 30 May 2002, 12:30 pm
renichms renichms is offline
Send a message via AIM to renichms
I have full air suspension and will soon be going for individual wheel control. Right now, it's front and back.
I have one compressor and one tank, both in the back. The tank is against the back seat, on the floor, and the compressor runs along the left side in the back. The compressor is powered directly from the battery, as are the buttons to lift and drop the car, so I can lift and drop it while the car is off (if I forget to drop when turning it off or at shows I can use it).
I'm having my buttons built into the car. The front up, front down, back up, back down and compressor controls are in the driver's side window pillar. For the up and down functions, I have red and black buttons, not actual switches. Push red to go up, black to go down. Those will stay there, with front and rear control, when I get individual wheel control.
When I do get individual wheel control, the extra 8+ buttons will be going near the parking brake, in the slot that fits pens so well (the tiny slot next to the "storage" area where CDs can go between the seats). I'll be having each wheel's individual controls there, sort of tucked away for only my use, or a passenger if I let them. As for side-to-side, I'll have to figure how to fit those extra left and right buttons in there too. But it WILL all fit. So I use no switch box and wouldn't really want one. This way, built into the car, the buttons are out of the way and take no pre-existing "storage" space.
My gauge, soon to be replaced with a lit gauge tied into the rest of the lights in the car, is in the coin holder. The line to it runs under the center console and comes out right at the cup holders through the coin trays. It's tilted so the driver gets the best view of it.
The guys who installed mine said a Cruiser will, with air suspension, readily lay the entire car on the ground (thereby crushing any body kits). Seeing that, they said the heat the exhaust and all produces might be too much for the lines if they ran under the car, so they've run the hoses inside the car, but tucked under panels so they're not seen or heard.
The tank is 5 gallon, I think. I don't know the size of the compressor, but it's small and quiet. If you have the stereo on and car running in traffic, it's easy to forget the compressor is on. I also can't remember the size of the lines but I think it's 1/4". The guys who installed it said if they had run 1/2", the car could jump.
Of course I think you know, the Cruiser typically uses struts in front and bags in rear. Bump stops will limit how low you go unless they're removed or trimmed. I'm going to get mine trimmed to be barely short of hitting ground at lowest. Right now, I can't put my foot under the exhaust tips or rear portion of the side skirts.
Mine lifts faster than it drops the car. It takes less than 2 seconds to go all the way up. The weight of the car is the culprit there, I'm told. It takes about 2-3 seconds to drop the car. My tank holds up to 150 psi and can lift the car, from ground to top lift, about 3-4 times when full. It can completely fill the tank, from empty, in a few minutes. If I intend to play, I tend to fill it completely and leave the compressor running while I do. NEVER let it run longer than a half hour or so. I let a kid play with it at a show and when I went to see if it was hot, the air around it was cool, so I touched the compressor and burned my finger.
Once I actually have individual wheel control, I'll be sure to give any extra information for it. It will allow for better handling and, as you said, "cool stuff."
Good luck with air suspension!
RN
See Mephisto
