well i installed the pcm before seeing the post about self tapping screws. i used 10/24 stainless screws with a lock washer, locktite and double nutted. it doesn't appear anything will rub and wear. What do you think about this install or should i remove and use the self tapping screws.
I took a short test drive and can see gretaer 1st gear power and higher boost pressures while driving in the 13 to 14 psi range.
