Rear Sway Install Problem
Decided to just go ahead a buy some aftermarket sway bars rather than wait for the factory issue to get resolved (kind of wanted bigger bars anyway). I went with the Eibach bars and got all the mounting hardware from my dealer.
My question to any of you who have installed a rear sway bar on your GT is: How did you bolt the retainers to the rear axle. According to the instructions in the Service Manual as well as the PT DIY site it says to just screw into the threads in the rear axle. My problem is that there are no threads in my rear axle. The only thing there is a hole which appears to be about 1/2" in diameter (located right above the slot where you hook in the retainers) but nothing that the bolt could "bite" into. Any help or advice would be much appreciated.
Mahalo,
Mark
