Thread: Wiper Arms
Old 23 Jun 2005, 08:15 am
quote:Originally posted by KingKole02
Ok, but if I do that how would I run the lines up the wipers?
Thanks thus far.
The wipers aren't on the hood. You'll need to take cowl off and I think you could get away with piercing the rubber hood seal at the back of the engine bay and running the washer lines the the rubber, since the lines are so small. Go under the cowl, and make a hole for the tubing at base of wipers.
See if home depot, etc, has small, rigid tubing to go thru the rubber seal with - you don't want it pressed shut when you close the hood....
