Old 02 Jul 2005, 01:25 am
SwtNLwPT SwtNLwPT is offline
There should be a hole on the driver side to run the wire. For the wire: to power your amp it should 8 gauge for most cheaper amps, but anything worth money most of the time you need 4 gauge. Your ground should never be smaller then the power either the same or larger never hurt. The ground should not be any longer then 2 feet. You hae to drill it into the sheet metal. You should also sand the paint off the area and make sure it touches the metal. The remote wire comeing off the radio can be 16 to 18 gauge and speaker wire should be 12 to 16 gauge.
Ride Hard, Ride Fast, but Ride Safe [8)]
http://www.cardomain.com/memberpage/529247
