If you want a good sounding system that doesn't cost a whole lot. Go with the JL Audio Stealth box. JL Audio TR series 6.5" Comp in the front (6.5" in the doors and Tweets in the does). Go with either the 5x7" Coax or what I did is custom make a plate for the 5.25" Coax for the rear. For your amp there is only one to buy. The e series 6ch. Amp by JL Audio Model e6450. This amp will power everything. Front, Rear and Sub. It will save in the long run. For your head unit go with the Pioneer, Alpine or even Sony. You will be safe Check e-bay or your local mom and pop place for this stuff. I had a friend in the business so it wasn't to bad for me to get everything. Should be under $1500 total. It sounds really good.
Ride Hard, Ride Fast, but Ride Safe [8)]
http://www.cardomain.com/memberpage/529247
