Thread: hitch receiver
Old 02 Jul 2005, 12:30 pm
satellite66 satellite66 is offline
Send a message via AIM to satellite66
Okay I did it. Less than 2 hours with basic hand tools. The hardest part was the third bolt setup. That took about 30 minutes of thinking to figure out and 2 mintues to do. Mine is an 03.
I jacked up the car and placed jackstands to support it. Remove the spare tire. Remove the ground strap from the muffler 10mm. Remove the six 10mm bolts that hold up the exhaust pipes and muffler. 2 bolts at the rear of the muffler, 2 bolts at the front and 2 bolts in front of the rear axle holding the pipe. You might be able to slide the pipes off the hangers but I just removed the bolts. Remove the factory tow tie down brackets from the frame rails. 4 15mm bolts. 2 on the side and 2 on the bottom of each bracket. Now comes the part that gave me pause the last time when I gave up. On mine there was an oblong hole in the bottom of the frame rail forward from the tow bracket holes. My kit had a rectangular shaped flat piece of metal that supports the third bolt which is a carraige bolt. I had to take a round file and file just a small notch in one side of the oblong hole in the frame to allow the support to slip in. Not hard. The tricky part was putting the carriage bolt into the support when it is up there. My solution was to take a thin piece of wire. I used speaker wire. I stripped back the insulation enough so I could wrap it around the carriage bolt at the end. I pulled the wire through the support bracket, slipped the carriage bolt in first then slipped the support bracket in. Gently pull the wire and the bolt should fall into the hole in the support bracket. The kit I got came with replacement bolts instead of using the orignal bolts from the tow brackts. The new bolts are the same thread but have 16 mm heads with lock washers and flat washers. I used blue locktite and bolted everything up. I torqued the 16mm bolts to 36 ftlbs and the nut on the carriage bolt, which is 17mm to 50 ftlbs. The instructions should give you the proper specs for whatever kit you get. Reinstall the exhaust hangar bolts. The ground strap on the muffler and the spare tire and you are in business. Mine has a 200 lb tonque weight limit. More than enough for the stuff I need to carry. I put 2 of the original bolts back in the holes on the side of the frame to close them off since they are not needed anymore. I hope this helps if you decide to do it yourself. Good luck it is not that hard.
If you live around central NJ and need a hand let me know.
2003 Electric Blue 5spd
Many on the political left are so entranced by the beauty of their vision that they cannot see the ugly reality they are creating in the real world.
