Old 27 Jun 2002, 07:27 pm
Gman Gman is offline
Stephen,
When it comes to brakes. There really is no moderate upgrade other then cross drilled/slotted rotors. As you said the ERADISPEEDS are unique by design. There is also DBA, Brembo, Stoptech, Power Stop. If you really search the net you can find some wild custom rotors that are used in road racing, SENECA makes a clover leaf design. But I am not going to pay the money $$$$ for outright custom rotors. You could just put on some Stainless Steel brake lines on. That alone you will get results. You talked about the WILDWOOD setup. Actually they are very reasonable in price with what all you get, calipers, lines and rotors. I've seen it for $620.00 from Summit racing. You also have to consider supply and demand. Not everybody is taking a PT cruisers and using it in a SCCA,ASA, sactioned type races around the country. Thats how allot of this stuff bleeds down to us, the consumer. If though your in the just the for LOOK department. Brakes are not the place to mess with. I have seen the results from the rice burner community go with just a look, and have seen the the damage.
