  #28 (permalink)
Old 07 Jul 2005, 12:26 am
ptgtcb ptgtcb is offline
Man, you guys still don't get it. If the newbies want to learn then they should hit search and the archives!
If you run an open element in the engine compartment then you will increase the air temp to the engine, no good, but the intercooler will work to bring the temp down. Show me the test where the the air charge temp is the same when entering the turbo and when it enters the intake, show me!
If you run a tube down to the brake duct then you may well introduce some cooler air into the turbo. Unfortunately, the turbo will heat up this cooler air and all your great mods are for not. If the turbo does not heat this so called colder and denser air the long tube that runs from the turbo to the inter-cooler will, the one that runs right next to the HOT oil pan. The reason we have an inter-cooler is to lower the air charge temp. A larger one will work, if, it is exposed to air flow and I do not see much room for a larger IC that would actually see any additional air flow. If you were to actually decrease the air temp below that of the inter-cooler then most likely it will work in reverse, you will actually raise the air temp after the inter-cooler. And, lets not forget the heat that is blown over the UUP pipe from the radiator, so much for the IC working, damn. UUP pipe is bogus, if anything it improves throttle response, that is it.
I do believe a ceramic coated upper and lower intake would keep the intake charge cooler, except for the other heat absorption problems our cars have. Maybe if the aftermarket UPP pipe were ceramic coated it could keep the air temp down and increase throttle response, this could be good I admit.
SI- SII WGA - Ign. Wires - Larger O2 housing - 3" CAT - 2.5' all the way back - LSD - Sway bars - shocks - Lowering springs and you'll be happy, your only going to get so much out of that little tiny weenie turbo anyway. GEEZ.
[8]
