Old 22 Jul 2002, 11:38 pm
purpleflames purpleflames is offline
I put Street Glow lights on my 2002. 54" on the sides and 30" front & rear. I removed the spare tire and holder to mount the rear. In front under the radiator there is a brace going across with 3 holes in it (just right for 3 wire-ties to hold front light. I put side lights on inside of the main frame chanel. Drilled small starter holes for the mounting screws. Did all the installation using the jack that came with the car. Put it just in front of rear tire and laid on my back. I ran the switch wire through the same place that your yellow wire is going through. Mounted the xformer on face of square computer module just above where the wire goes through. Mounted switch just under the knee panel under steering wheel. Bought a different switch at ACE hdware with a mount.
