Old 16 Jul 2005, 12:19 pm
gonzomania's Avatar
gonzomania gonzomania is offline
Send a message via AIM to gonzomania
CruzinAlong have you done a search here?
1st have you replaced plugs and ignition wires. Wires maybe beaking down. Many have done this because OEM wires are cheap
2nd If you have rear drum brakes I believe it's the quality of metal used,again OEM drums are cheap. Live with the squeal or replace them drums are like $75.00 per. My rears make noise but I'll wait till I need rear brakes then change them. Also pads may be glazing over.
3rd,4th & 5th no clue
6th Mine does this also I believe it's the exhasut pipe or muffler bouncing up and hitting the bumper or undercarriage.
Hope this helps. Hang in there the car is worth it!!!
Gonz
