Thread: which plugs?
Old 19 Jul 2005, 08:52 am
quote:Originally posted by dfunkdj
I have the denso iridium plugs in my Pt you need a specila socket to get them in and out because they go in deeper and a reg socket will hit the side of the valve cover and not let you get the plugs tight. I dought if tommy had thees plug re machined after after buying them from NGK.
Don
They don't "go in deeper" - it's a matter of where the "nut" part is on the plug. They're not designed for the PT, the Champions are. The plugs aren't ground down, the socket is.
