Old 22 Jul 2005, 10:36 am
tpscruiser tpscruiser is offline
The screws are sort of a screw/push pin. Try turning them counter-clockwise with a small screwdriver WITHOUT putting much downward pressure on them. When the screw head is a little above the surface, try to pull it straight out using your fingernails or needle nose pliers then pull the retainer out out the cover also then lift the black cover/screen off.
John & Terry
"His" - 2002 Inferno Red Touring Edition
"Hers" - 2003 Electric Blue Limited Edition
Del Val PT Cruisers
