Old 25 Jul 2005, 10:04 pm
AZ_IceMan AZ_IceMan is offline
Send a message via AIM to AZ_IceMan
You could be setting off a CEL code. More than likely it is the part throttle boost code. Let me know what code you get next time the check engine light turns on. If you are spiking boost too high then the ecu is pulling timing and that would also explain the sluggishness.
<div align=\"right\"><h2><b><i>Can we say Sleeper?</i></b></h2></div id=\"right\"><div align=\"right\"> </div id=\"right\">
