Stage I was the last mod I did before the hyperground. I found that the "crispness" would fade over time so I installed a battery disconnect swith to the ground and every so often I disconnect the battery and it goes back to a learning mode. After that I do a couple of WOT's and the throttle is more responsive and the shifts are crisp. By far the biggest bang for the buck seems to be the VAK UCP. When that was installed, before Stage I, I thought I added 50 HP [8)]
The quick learn isn't difficult, although I had marked down the number of "runs" needed and checked them off as I did each one. You only have to get to 55 so you have to watch out because it only takes a few seconds to get there with Stage I.
Good luck, and try to keep a streight fast after you install it. [8)]
Inferno Red \'04 GT Autostick, Stage I, BTG exhaust, Airforce One intake, V.A.K. Candy Red upper charge pipe, BTG strut bar,Hyperground, chrome side spears and grill accents.
