Your using a Whipple Supercharger and complaining cuz your clutch is not holding up[V]
What'd you expect man? Your 5-spd is not even a heavy duty one like the Getrag 5-spds that the GT's have. The clutches are different also with the GT clutch being heavier duty. If your going to "beef up your engine" with a SC/Turbo/Nitrous you should be thinking about the clutch and axles too. At least your not driving an automatic like 80% of Cruiser owners out there...those things are failing on a bone stock engine and upgrades are costing $2500 plus labor. At least you can fix your problem for a paltry $550 if you do the install your self.
Deen
