Old 02 Aug 2005, 04:29 pm
MichaelDay MichaelDay is offline
As long as you limit your towed weight to the maximum 1,000 pounds your GT will make a good tow vehicle. The turbo has good mid range torque and comes on smoothly so you should have no problems at all.
The brakes will take a beating since the PT hasn't got the best brakes around anyway. If you are loading the PT up, as well as adding close to a 1,000 pound trailer, your brakes will heat up pretty fast. Just go down hills in a lower gear than you normally would and don't ride the brakes.
