quote:Originally posted by JoePro
Guys,
you have been less than spoiled, but you have had your wallets emptied.
You won't find hard-core racers fiddling wround with the siully "stage 1" hoax. Stage 1 is a 15 to 25 hp "gain" that can be had without spending a ton of money with two cheap parts.
Boost gauge & manual boost controller.
Boost gauge: $25
Manual controller: $15
Net gain on pump fuel (97 octane) = 35 to 45 hp easy.
a "Cheapie chiller" or a windshield wiper pump with 4 to 6 outlet ject than sprays a 70/30 water/alcohol mix onto the intercooler at the press of a switch or at WOP costs about $20, and yields another 15 ponies on a hot day.
Save your money. Forget the "Mass Market Dupe of Stage 1. Do what the racers do.
i try all the modification you said but its dont work overboost code and with a boost controler you ave big power just for starting and the wastegate is too soft so you ave noting after stage one is the best and if you put mbc change your wastegate for a stiffer and after change your autotranny lol
