Old 14 Aug 2005, 01:17 pm
Espresso Espresso is offline
Why reset the ECU when changing plugs & wires? What would you do when adding a 50 shot of nitrous oxide?
You only need to disconnect the battery ( both pos & neg) when working on something electrical. I've taken out engines with out even touching the battery. The only reason you need to do it is for safety, not for the ECU to "relearn" A/F ratio's ect..
