Old 14 Aug 2005, 01:25 pm
Espresso Espresso is offline
Check your fluid. If it is low...add. If the light stays on suspect the switch. They are about $20 & easy to replace.
Also check for leaks. If you havent had the hose replaced under recall. I would SERIOUSLY get it to the dealer. Quite a few PT's have burned to the ground because the hose leaked fluid & caused a fire under the hood.
