Old 11 Nov 2002, 03:08 pm
Sci-Fi Sci-Fi is offline
quote:
Excessive noise coming from power steering...pleanty of fluid and seems to be worse on cold days...increase effots and feedback thru steering wheel entering driveways Any ideas?
Take it in to the dealer and have them replace the power steering unit under warranty, if the belt isn't slipping, needs adjustment, or replacement. In rare instances, the rack and pinion assembly may need to be replaced. Hopefully, you used the recommended ATF+4 transmission fluid if you added any fluid to the power steering or transmission for that matter. The use of any other transmission fluid type may void your warranty.
It's nice to be important, but it's more important to be nice.
