Old 18 Aug 2005, 04:17 pm
jtdev jtdev is offline
First start with checking the oil. (If you ran it out of oil it will stop and never turn over) (Also check the radiator fluid. If your head gasket leaked, you cylender might be full of antifreeze which does not compress and thus you cannot turn engine over)
Then check the starter (bypass the ignition system and it should turn over)
If starter turns, then check fuses, ignition switch (things like that)
Is it a 5-sp? It also could be the clutch safety switch.
Just some things to check on.
GT is the only way to go
