Old 19 Nov 2002, 11:53 pm
Sci-Fi Sci-Fi is offline
As far as the throttle spacer, here's a letter from airaid:
Subject: Re: AIRAID.COM Contact Form
Date: Fri, 09 Mar 2001 09:20:36 -0700
Dear Sir, thank you for your inquiry in our products. The spacer makes no HP on the dyno. It makes all of it's power in torque in the low end. If you haven't noticed any power on the Dyno or the track then it's doing what it's supposed to. You would not see any gains down the 1/4 mile or increases on the dyno. The idea of the spacer is to improve overall drivability and fuel mileage. In most cases when people install a bolt on part they expect better mileage and power, what happens is they are into the throttle a lot more than before trying to test performance and thats when the decrease in mileage happens.
Sincerely,Matt
And a comment from the DodgeDakota Forum:
So...
(1) "The spacer makes no HP on the Dyno. It makes all of it's power in torque in the low end.". - That's a quote from AirAid.
(2) "If you haven't noticed any power on the Dyno or the track then it's doing what it's supposed to." - Another quote from AirAid
(3) "The idea of the spacer is to improve overall drivability and fuel mileage."
(4) HELLO...HP and TQ are BOTH measured on the Dyno. Guess the didn't see any TQ gains either...and they can't provide any proof.
So...it doesn't make any more HP, is NOT supposed to help in 1/4 mile performance (or on the Dyno), and is mainly for mileage and bottom end Torque. Hmmmm...Dyno's show TQ figures and there were no changes, mileage stayed the same, and 1/4 mile performance wasn't affected on the several people who have tried it (including myself). Hey, that's worth the $90!
BTW: They still aren't able to explain how the spacer keeps the swirl effect through the two turns (90 degree and 45 degree) in the intake plenum of the Dodge Ram/Dakota/Durango manifolds.
It's nice to be important, but it's more important to be nice.
