There are two people at another PT site who have larger turbo's. One just received his upgrade a day ago and has not installed it yet. Another guy is sorting out the various problems associated with a new "toy" and still has yet to get it all sorted out. Presently he is making more power than the factory clutch can hold and will need to install an aftermarket clutch. Luckily there is a clutch out on the market that can handle upwards of 500 HP that will fit our turbo PT's.
For Cruisers with an auto tranny you will need to upgrade to a HD automatic if you go with a larger turbo...they are available also.
My guess is if you check back about springtime you will find 5-6 PT's with larger turbo's that have all the necessary modifications and results will be posted by then.
Deen
